Hi guys,
I have a 1990 jdm st185 and i have just fitted a kinugawa 3071r turbo to it with a fmic. The turbo came pre installed with a 1bar actuator spring but i am only getting 7-8psi. I have the vac line to the tvsv blocked off which i thought would allow it to run on wastegate pressure.
So my question is do i still need a boost controller installed for it to reach wastegate pressure or should it be hitting the 1 bar boost as is and i have an issue somewhere with my setup?
TIA
TIA
