I've always noticed a little hesitation when The Lorelei isn't warmed up to full operating temperature.
I've also always seen a low idle. It tends to settle in at 600rpms +50. I talked to a former Toyota Tech and he told me that I ought to be able to adjust idle by opening up the set screw at the front of the throttle body where the air intake is. Here:
After opening it up a turn and a quarter, the idle was set at 800rpm. I then took it on a 125 mile drive. Halfway in, I got some rather extreme hesitation. Not stalling, but not accelerating either. But then it would kick in, intermittently, creating a herky jerky condition. I pulled over, turned the car off, turned it back on, and then drove home. I was gentle because I could feel that it just didn't have the vigor. I drove 60 miles home at speeds up to 110km/h, so it isn't like there's a gross mechanical problem.
Once home, I reverted the set screw back to the original position, disconnected the battery, touched the positive and negative terminals to each other as an effort to drain the ECU capacitors. I also disconnected the EFI and Hazard fuses and the EFI Main Relay. My thought was that perhaps changing that set screw had messed up the computer's sense of reality.
The next morning I hooked everything up, took it to get coffee, and everything was fine. Got it on the expressway and gave it the beans and it was responsive. I took it on a 100 mile drive, and performance was flawless--good responsiveness, and everything you would ask for. Temperatures were cool.
I drove it to work today, no problems on the way in. But on the way home I got the hesitation again. Temperatures were brisk. This is what it looks like:
https://youtu.be/z4WyUioWGIo
Symptom--Engine Hesitates And/Or Poor Acceleration is one of the longer troubleshooting chains in the Big Green Book:
Clutch or Brakes? Unlikely.
Vacuum Leaks in Air Intake Line? No. Checked recently with Throttle Body Cleaner.
Air Filter? Extremely unlikely. New K&N installed a couple of weeks ago.
Check Diagnosis System? No "check engine light," continuous flashing of engine light when TE1 and E1 connected and ignition switch to on but engine not started.
Check Ignition Spark? Possible. Is it possible that the distributor is malfunctioning intermittently?
Check Fuel Pressure? Possible and somewhat more likely. Air-Fuel mixture goes full lean when the problem manifests.
Check Injectors? Unlikely. Car performs well when problem not manifesting.
Check Spark Plugs? Unlikely. Car performs well when problem not manifesting.
Check T-VIS Valve? Possible. I don't have the equipment to test this nor the knowledge.
Check EFI Electronic Circuit Using Volt/OhmMeter. Wiring connections, power to ECU, Air Flow Meter, Water Temp Sensor, Intake Air Temp Sensor, Throttle Position Sensor, Injection Signal Circuit.
My sense is that there's something wrong with the fuel system--like the engine is not getting the fuel it needs. The Air-Fuel Ratio meter is handy for this, because I can see that it goes lean. I have not changed the fuel filter. The fuel pump is the original fuel pump. I do not have a fuel smell in the engine compartment or about the undercarriage that suggests a leak. Been running 93 octane. Alternately, it might be the Throttle Position Sensor. I tried to test it, but I couldn't get the screws to loosen up and I'm not stripping the cross-tip heads. Alternately, if the Air Flow Meter is malfunctioning, it could be telling the motor not to work.
If you got this far you are awesome in my book. Thoughts?
