My Alltrac Nutshell.....
Note: the above is not current picture
They both need some TLC.... and all the pictures in the links below are current.
1991 ST185 149K
https://photos.app.goo.gl/rUHMrQXyz2TiVXE67
Rebuilt engine at 100K, currently it seems to have a issue with #2 fuel injector
Also at 100K I swamped in an RC transmission, no testing lever, plus the RC shifter.
ACT Clutch
Fandanza light weight flywheel
2.5 inch KO Racing Downpipe, 3 in mid-pipe, stock on back
HKS Boost Controller,
New Gas Tank and Filler neck about 2008,
About 2019 an essentially new fuel pump bracket
Replaced Fuel Pump Bracket, not new but almost NIB
Braided Steel Clutch line
Clutch Master Cylinder was replaced.
Fuel and brake lines
Struts, sway Bar links and bushings, front and rear
Emergency brake cables
Radiator and ALL hoses, including heater lines
Replaced ABS Cover
New Alternator
New windshield (not Toyota)
New supra bushings in rear suspension
New front strut bearings
Sunroof wind deflector
Factory Rims with Blizack Snow tires... yes I had fun
Plus, a second set of factory rims, no tires.
New parts pending install: SS Brake lines, front ball joints (AutoZone), A Arm bushings (AutoZone, see parts dept...)
JDM part for install: a complete Subframe and Diff from Japan, very clean. ( see parts dept...)
Body: it does have rust issues the Rockers are shot and one of the sub-frame mounts needs TLC.
Rear fender lips are good.
the bottom half of the car had been repainted about 2008;
No foam, I did weld in patches over the years and sprayed it with oil....
Interior: mostly stock, pilfer gauges but no holes, door speakers were replaced, front seats have issues.
Engine: was running great until... the Fuel Pump bracket sprung a leak. Hard to locate but found one that was essentially new.
Shortly after installing, it got a bad miss which I believe to be #2 injector. Transmission and drivetrain, good. the Tachometer needs a capacitor repair.
It has never had a Fuel Cut mod...
It does have an ODB2 interface to provide the following data to the Tourque Appliction on my phone: AFM, TPS, Vacuum/Boost pressure, Injector duration, RPMs
Spare Parts: See the list, I also parted out a 1990 AT
History: I bought this AT from a Doctor with a blown transmission at 59 K. At about 100K I discovered a head gasket leak while driving to pick up the RC transmission.
Pulled the engine,, new rings, water and oil pumps, T belt, seals and such, plus the RC upgrade. Turbo has always sup up just fine, the EBC is nice.
I put 90K on it and must say it was fun.
My DIY Boost Gauge.... yeah, the music
https://photos.app.goo.gl/Zy6NyhQQSExvsxpV8
The Arduino ODB2 interface and Torque on my Android
https://photos.app.goo.gl/7n2YmG9HQk3886Xz7
This AT went off the road in 2015 due a leak in the fuel pump bracket piping. I eventually found one, got it fixed, but shortly thereafter it developed a bad miss.
Which I believe to be #2 fuel injector.... maybe just a fuel filter.
1988 St165 150K
https://photos.app.goo.gl/nnDzBXnY7G8oBDuN6
2nd Gen engine, extended JDM wiring harness, JDM ECU, single wire O2 sensor, JDM (no EGR) head).
Engine rebuilt with new pistons, bearings and put in at 114K on the body.
Turbo, is a CT27, I it rebuilt, but I think the wastegate does not fully close, boost tops out at about 10lbs, more later.
Straight Air intake.
3 inch Downpipe, 3 in mid-pipe, stock on back
larger Greddy IC Radiator
HKS Blow Off valve
HKS VPC, temperature sensor is installed into the Intake Manifold, but that is all
Powder Coated Intake Manifold
Centerforce clutch
lightwight flywheel,
a Corolla (I think) custom short shifter. It is nice...
SS braided brake lines to the calipers
Front wheel bearing have been replaced.
Front ball joints and A Arm bushings were replaced (Autozone).
New Toyota Front rotors (a bit rusty now).
Replaced the power steering rack (not Toyota)
Front brake cylinders have been rebuilt. Toyota kit for the Reass included....
Nw starter
HKS temperature Sensor is installed into the Intake Manifile, HKS FPS _____ included
Summit Racing WB O2 gauge
Turbo Timer
Battery is in the trunk.
New outer seals in the rear diff
Suspension: it has adjustable shocks on the back, I had done the cut andd weld for MR2 shocks....
the Front. also adjustable KYB struts....
The front end got banged up and the FR bumper horn was damaged a bit. I put it into a frame shop and had it repaired.
The FR Struts was damaged and I had to use the struts from the "other" 165,Ground Control Coil Overs, which are now non adjustable..
Those coil overs were adjusted for a very low ride.
The alignment shop said they could do a much better job if the coil overs were adjusted up to match the rear....
That project is pending....
Body: This car, a Blue 165, came from somewhere down south with a clean body and a blown engine which someone tried to squeeze to hard.
I already had a Grey 165 from "Silence", which ran good, but had it's own issues.
I traded with "ScandinavianLink" and some time later I bought the Grey 165 back from someone else as a parts car.
So with the above mentioned bang up the front bumper, grill hood and fenders from the Grey 165 got swapped onto the Blue 165.
I also used the console from the grew car in teh blue car.
All was reasonably well until a break line failed. I had replaced the brake and fuel lines some time ago....
Which predated the newer lines available which are easier to work with and more corrosion resistant.
Other than brakes it could be driven... The fuel lines are OK, but should be replaced as well.
Body: again, this car came from down south and was in very good shape. I cleaned the underside, removed the subframe and gas tank and then painted everything with Rust Bullet.
The trunk lock needs TLC...
The seats are in reasonable condition. The dash has a bubble.
Stock Rims with Blizacks included.
Boost Controller: Manual Boost Controllers are a pain. Electronic boost controllers were expensive.
I made one using an Arduino which also displays the AFM, TPS, Vac/Boost pressure. The display is shot but I have a spare.
https://photos.app.goo.gl/hYTUj89Tzbrr3Rjz6
Currently it does make some smoke after it warms up. I suspect the turbo needs a wiggle test. Note: other parts includes a stock turbo replacemnt....
The link below is to a spread sheets for parts...
I parted out a grey 165 and a teal 185 so there are lots of parts.
The "Other parts" includes the below, and more
- a Complete engine, Turbo, transmission, wiring harness and ECU as pulled from a 1990 AT with about 113K.
This engine ran fine, the car got hit while parked and deemed beyound fixing. (the below are not the same)
- 2 Transmissions
- 2nd gen Turbo, was working OK when pulled, about 140K
- 2nd Gen Head, no know issues, replace by the above JDM head in the 165
- 1st Gen Turbo, crack on exhaust side
- 1st Gen Head, from the blown 1st gen head, has oversized valves....
Parts List: https://docs.google.com/spreadsheets/d/ ... sp=sharing
ST165 Parts Pictures: https://photos.app.goo.gl/6QJfuNRTCVDTdYw97
ST185 Parts Pictures: https://photos.app.goo.gl/o9tCk8TVfKwFcf198
Plus Other Parts: https://photos.app.goo.gl/th1QzD3Ap2prE6wr5
1991 ST185 149K
ACT Clutch
Replaced ABS Cover
New Alternator
1988 St165 150K
HKS Blow Off valve
Centerforce clutch
Nw starter
Turbo Timer
- 2 Transmissions
