CosmicWanderer
Well-known member
- Joined
- Jun 30, 2024
- Messages
- 95
Hi y'all,
For those who read my introduction post, you already know the catastrophic failure of cylinder #3. Now, I've started to order some parts, and hopefully, after the summer season, I'll start working on the car. Need an overhaul, almost completely - crankshaft & connecting rod bearings, thrust washers (why not? ), pistons w/ pins, piston ring set, valves, valve seal / o rings, timing belt, timing belt tensioner, two idlers of belt, v-belt, vane pump belt, etc.
I've got 3 part numbers for the pistons, and I'm not sure what's the difference between them. The prices differ from each other. I don't know which one fits my ST185L-BLMVZG.
What do those really mean? Mark 1,2,3? O/S 0.50? Or maybe I should open it up to see if there are any stamps on the piston(s)? Attached are some shoots of piston no. 3.
Regards.
131018838101 | 3SGTE..ST185 STD,MARK 1 |
131018838102 | 3SGTE..ST185 STD,MARK 2 |
131018838103 | 3SGTE..ST185 STD,MARK 3 |
1310388381 | 3SGTE..ST185 O/S 0.50 |
Regards.
