shadowsun06
Member
hello all,
I know that this subject had been talked about multiple times, but I see that everyone have different solution (for different usages )
I had found front and rear st205 brake calipers for 1000€ (a bit pricey) with spacer and rotors (dont know what model) for mounting on st185.
For mounting the brake, I need :
- remove the front and rear dust plate or bend them
- find rotors that fit (diameter + center diameter + ) does st205 rotor work on st185 ? I think yes but with center ring since I had read that the st185 hole diameter is lower that st205 (54.1mmvs 55mm ?)
- find pads that fit (st205 again ? )
does the parking brake work with st205 rotors ?
I am looking for Oz chronos wheels (17") does they have enought clearance ?
does the st185 brake line (HEL) work with st205 calipers
