Rather than scatter the information in various threads, this thread's purpose is to educate all ST185 owners as to what size wheels are possible on their vehicles.
STOCK WHEEL SIZE
15x6.5 +39 offset
This means the stock wheels extend 47.25mm out past the hub and 120.25mm inside the fender from the hub.
TEST DATA
What we know fits on the front:
17x8.5 +35 (no rubbing at all)
17x9 +30
What we know fits on the rear:
17x9 +30 (rear fenders rolled)
17x10 +5 (sticks out slightly but has 12.5mm of clearance on the inside)
Conclusions thus far:
The max we've seen so far on the front is 142.5 mm on the inside and 82.5mm on the outside.
This means a 9 inch wide wheel on the front is very possible with something near a 30mm offset.
The max we've seen on the rear so far is 130mm on the inside and 120mm on the outside.
This means a 10 inch wide wheel should fit with an ideal offset of +10 or +12. A 9 inch wide wheel with a near 30mm offset, as stated above will also do nicely and should fill the fender well.
MORE COMPLICATIONS
If you're like me, for the circuit you prefer to stretch the tire and use as wide of wheels as possible. Keeping in mind the AWD, you most likely want to have all 4 wheels identical in at least width. If you crave deep dish like me, you know that the lower the offset, the deeper the lip you can obtain. How far is too far? Camber also affects things here, even only a few degrees of neg. camber can save a wheel or make it rub. Let's explore...
This is claimed to be 17x9 +30 all around. It looks good but could be pushed out wider slightly more. SLIGHTLY
This is claimed to be 16x9...my guess is the offset is somewhere between 0 and +10. I might bring in by 5-10mm but it's close to what I consider to be perfect. (though the wheel design itself is fugly hehe)
In my opinion, these wheels are perfect. They are totally flush. The fenders are rolled and it does not rub at all.
WHEELS THAT FIT THE TICKET
So far, hands down goes to the Speed Star Racing (SSR) Professors for being extremely versitle and flexible in every aspect. They are 5x100 friendly and can be had in virtually any width, size, and offset. (They're also damn sexy and reasonable in price) They can be ordered in custom colors for about $30 more per wheel.
The Volk GT-C is another inexpensive wheel that works. Unfortunately, we are limited to 8 inches in width, however, they do have a low (16mm) offset available which would give you about 2.5 inches of lip and extend out to the fenders quite nicely. They're also quite inexpensive and are available in custom colors for about $30 per wheel.
Let the discussion begin![/img]
STOCK WHEEL SIZE
15x6.5 +39 offset
TEST DATA
17x9 +30
MORE COMPLICATIONS
