Hi all,
As some of you may read before, I'm installing RC engine in ST182...
The project is almost done but I've left with 2 small vacuum pipes that I'm not sure where they should go.
The 2 pipes are very small ones, coming out from the bottom side of the intake manifold on the right side (timing belt side).
I assume one of them goes to the on the valves cover top, right?
Where the 2nd one goes?
Thanks.
Thanks.
