alltrac.net gtfour.net
Celica All Trac
It is currently Fri Sep 10, 2010 6:59 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
Author Message
 Post subject: Re: 5x100 to 5x114.3 spacer adapter
PostPosted: Sat Apr 10, 2010 1:43 am
Offline
The 050 is discontinued, but there was a member selling chrome ones a while back. You might be able to find the thread on here. I'll sell mine someday, but only when I am ready to upgrade to something else.
18s look fine on our cars if the car is lowered right. Some people think they are too big, but they also think 16s is going large.
_________________
92 st185 | 03 350Z Track
Nori Toy | Deviant art
 Profile
PostPosted: Sat Apr 10, 2010 7:21 am
Offline
HA! well if they think 16's are too large, i think 18s will do me fine. alright man, i think i've learned a lot. seriously considering the xxr 502's. thanks again for all your advice.
_________________
Black '90 st185
1997 Jeep Cherokee
Sold!
 Profile
PostPosted: Sat Apr 24, 2010 12:15 am
Offline
hey cms, i have sold my jeep and now am seriously going to buy wheels and tires. quick question is- running xxr 502 18x8.5 and 18x9.5 what tire size would you recommend? i'm thinking 245/35/18 up front, and 255/35/18 in the rear. and with this will i need spacers? the offset on these wheels is 35.
_________________
Black '90 st185
1997 Jeep Cherokee
Sold!
 Profile
PostPosted: Sat Apr 24, 2010 12:39 am
Offline
I honestly do not know tire sizes for staggered. I would look at Pat C's tire sizes he ran on his 18s to be safe. Simba also runs staggered 18s, and so does that st205 I posted. You can use the tire calculator to see if your sizes are close enough.
http://www.miata.net/garage/tirecalc.html
Be sure and post lots of pics if you do it.
_________________
 Profile
PostPosted: Sat Apr 24, 2010 12:53 am
Offline
alright man i will do that for sure. thanks a lot for all your help. do you think spacers will be needed? i just don't wanna get everything and then need something else. lol
_________________
Black '90 st185
1997 Jeep Cherokee
Sold!
 Profile
PostPosted: Sat Apr 24, 2010 1:39 am
Offline
There is still a good chance you will need a rear 20-25mm spacer. It might be best to get the wheels, and test fit the rear, then you can decide how much spacer you want to run.
The calculator says this setup will run about 1mm further out then a 9" wide wheel at 30et when using a 25mm spacer.
http://www.1010tires.com/WheelOffsetCalculator.asp
Remember you will also need to roll your rear fenders, and the car will look like a monster truck 4x4 unless you lower it.
_________________
 Profile
PostPosted: Sat Apr 24, 2010 5:41 am
Offline
alright yeah that sounds like a good plan. and i know. my car looks like a monster truck right now, so i definitely have plans of getting coilovers and dropping it a few inches. queston is which to get... toss up between ksports and bc racing.
_________________
Black '90 st185
1997 Jeep Cherokee
Sold!
 Profile
PostPosted: Tue Apr 27, 2010 1:06 am
Offline
okay, i think i've decided. i don't wanna do staggered cause its just to much of a pain in the ass. for not much gain. so, if i dare say, i think i'm gonna try to make 18x9.5 fit all around with 255's. i know this was advised against, but i'm willing to work with it. am i just in for hell?
_________________
Black '90 st185
1997 Jeep Cherokee
Sold!
 Profile
PostPosted: Tue Apr 27, 2010 1:47 am
Offline
What wheel are you thinking? You might consider using the 245, then again the 255 might stretch some as well.
Pat runs a 245 on a 9" wheel w/ 25et for the front. If the offset calculator is right, then a 32et 9.5" wheel will have the same inner clearance as my 38et 9" wheel and only be outboard a couple more mm then a 30et 9" wheel.
The tire size may be what causes any clearance issue, but it might be stretched enough to be fine.
Good luck.
_________________
 Profile
PostPosted: Tue Apr 27, 2010 4:54 am
Offline
i was thinking about running the XXR 502 staggered 9.5 and 8.5, but it seems a lot more simple to just run same size all around. and like you said, i think with the same size tires as your running i shouldn't have anymore issue's with the wheel being .5in wider. anyways, i'll look into it some more and hopefully be able to have some pictures up soon instead of all this talk. btw-255 on a 9.5 isn't going to be streached to much will it?
_________________
Black '90 st185
1997 Jeep Cherokee
Sold!
 Profile
PostPosted: Thu May 06, 2010 5:26 am
Offline
what wheel width and offsets would give you flush in the front and the back?
17x8 et35 in the front?
17x9 et35 in the rear?
 Profile
PostPosted: Thu May 06, 2010 6:30 am
Offline
i'm not sure man. i'll be showing you all what 18x9.5 looks all around here soon. what seems like a perfect set up would be 9 width all around with the perfect offsets so you'd acheive a staggered look just with offset. so you would have more wheel on the outside of your hub in the rear and more wheel on the inside up front. what these offsets would be i have no idea. i also know it would take plenty of $$$. so i just went with the cheaper option. lol
_________________
Black '90 st185
1997 Jeep Cherokee
Sold!
 Profile
PostPosted: Wed Jul 28, 2010 2:24 am
Offline
Ok I didn't want to start a new thread concerning the 5x100 to 5x114.3 lug conversion just to ask this one question but has anyone ever considered simply drilling new holes in the existing hub for the new bolt pattern. I have not taken measurements to see if the pattern would fit but I believe it is a possibility am I correct?
Jon
_________________
90 St185_DD/Autocross
90 St185_under construction
92 Celica Gt_Runnig
 Profile E-mail
PostPosted: Wed Jul 28, 2010 8:08 pm
Offline
Not on the fronts, there is not enough material on the diameter of the hub to do it safely.
_________________
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
